How to append string data to a table?
I am trying to append data to my table but is just overwriting the previous result. Have tried to use a shift register but still overwrites. I have attached my code for a perusal.
Message Edited by Molly K on 02-10-2005 09:25 AM
(4,269 Views)
The vi is called SCOPE TEST
(4,264 Views)
Read the data (Unbundle), pass it to Insert Into Array, and connect the output to the Bundle node.
If you leave the indexing terminals of Insert Into Array disconnected it will append.
Lynn
(4,257 Views)
Try this (LabVIEW 7.1):
(You still need to polish it up a bit, eg. add means to clear the table, or prevent it from growing indefinitely)
(4,251 Views)
Thanks for the help but the initialise vi creates an error code now. Any ideas??
(4,215 Views)
Hi Grant,
What's the error code????
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(4,188 Views)
Re-booted and restarted labVIEW and problem cleared. MMmmmm? Works OK no anyway thanks.
(4,184 Views)
