How to apply Gaussian fitting for a continious signal received from photo detector.
Hello all,
need your help.
I need to know how to apply gaussian curve fitting for the signal recived from Photodetector.
like i need to save data contionusly, seperately both the gaussian fitted and also the same signal without fitting.
Thanks in advance.
(2,593 Views)
Have you tried the Gaussian Peak Fit VI from the Mathematics >> Fitting palette?
How fast are you acquiring the data? What size data blocks are you fitting?
Please post what you have tried so far, along with a sample data set (if not too large).
Lynn
(2,552 Views)
