08-01-2006 07:40 AM
08-01-2006 08:54 AM
08-01-2006 09:14 AM
Hi Jonnie,
thanks for the VI. In your example everything works fine. The "big plot" is associated with the "big skale" and the "small plot" with the "small skale". Anyway: In "Properties" >> "Plots" the Big Skale appears for both "Small plot" and "Big plot". I cannot switch it to small plot. It just keeps jumping back... this is the same problem I had with my own graph.
Do you have any idea?
08-01-2006 10:01 AM
08-04-2006 02:36 AM
Hi Jonnie,
it just wouldnt work the way we tried it. I now assigned the plots to the y-skale with right-click on the plot in the plot legend >> Y-skale. Surprisingly it worked this way. I don't know, what the problem is with the properties window.
Thank you anyway... ![]()
