Read BMP file returns "rect" cluster, from it you can know width and height of picture. Set property node "DrawArrea Size" of Picture control to this data. Look attached example.
Hi Mark. Was wondering why you didn't set the fit mode in the .uir to stretch to fit image, or programmatically use:- SetCtrlAttribute(panel,control,ATTR_FIT_MODE,VAL_SIZE_TO_IMAGE); Best Regards Ken Green
