How to auto resize my FP respect to graphic card resolution??
I create standalone exe from a graphic card resolution 1280*1024, when i use the exe in low resolution graphic card pc (i.e 1024*768), front panel or all my sub panel shift out of position. Any idea how to fix this problem?? Any settings for the vi properties??
regards,
Simon76
(2,809 Views)
Ya, you ve reached for the answer by yourself.! Smiley Wink
See the attached pic for the settings in the VI Properties window.
This is for LV 7.1.
- Partha ( CLD until Oct 2027 🙂 )
(2,804 Views)
Beware that font sizes won't change so you need to find a compromise or manipulate fonts by code (which is painful and seldom satisfactory).
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,797 Views)
Hi guys,
Thanks for the suggestion. I still need to modify a bit the FP as Paolo mentioned seldom satisfactory and painful.
Simon
(2,783 Views)
