How to automatically name files which are saved using " Write to spreadsheet" individually?
I'm making a program which will save image data (i.e pixel intensity) and the save the data to a text file. Works great but I need it to automatically name each textfile as I will be taking n number of image date in a certain amount of time and don't want to waste time writing each file name.
Any tips would be hugely appreciated,
Shack
(2,899 Views)
Hi Shack,
you need to create your filename programmatically. As they are just strings you should use string functions to do so!
Then use "Append Path" to create a full filepath wired to your file function…
(2,895 Views)
Okay I think I understand, I'll give it ago now.
Thanks for your help 🙂
Shack
(2,885 Views)
(2,882 Views)
