How to average and subtract waveforms
Hi Tugez,
the waveform subtraction is working as expected:
Maybe it's time to check that function from the toolkit you are using?
I guess, you get similar results before and after subtraction because the red line is rather flat and does not provide as much influence as you expect…
Message 11 of 13
(1,412 Views)
Here I subtract mic2 from mic1, so difference in result table 2 should be near 0. But it's not.
Message 12 of 13
(1,391 Views)
If your raw signals are in volts or pressure units and the displays are in decibels, this might account for the difference. Subtacting logarithms (decibels) is like dividing the original signals.
Lynn
Message 13 of 13
(1,364 Views)
