How to avoid NaN
No, this here!
Hi Imtis!
Message 21 of 37
(1,493 Views)
Its under  --> programming --> string --> Format into string
Mathan
Message 22 of 37
(1,491 Views)
sorry for the previous post....
Its under,
programming --> File I/O --> Write to spreadsheetfile.vi
Message 23 of 37
(1,486 Views)
Yes, they changed the icon in LV 8.0
Jim
LV 2020
Message 24 of 37
(1,482 Views)
oh thanks guys,
I've seen it!
Lauvia
Message 25 of 37
(1,472 Views)
goodday everybody,
could someone tell me how I can save this string array without using the VI "string to number"? see the pic!
the second question, how could I add a printer VI?
thanks
Message 26 of 37
(1,424 Views)
Hi Lauvia,
you can use the string vi of this type. right click on the vi and change to auto select or string. To print your data you could use the Report vis.
Mike
Message 27 of 37
(1,422 Views)
Message 28 of 37
(1,417 Views)
Hello Mike,
are you using LabView 8.x ?   I have the 7.1 version. so I dont have the same pulldown menu
Message 29 of 37
(1,415 Views)
Hope this helps,
Mathan
Message 30 of 37
(1,405 Views)
