How to avoid that vis written in LV7.1 automatically open in LV8.5.1
I have newly installed LV8.5.1 which also have LV7.1 installed. I noticed that the older vis now automatically open in LV8.5.1. If I save them accidentally, I will no longer be able to execute them with the older LV version. How can I avoid that Windows associates those vis with the new LV version?
Thanks.
Peter
(2,436 Views)
See here.
(2,430 Views)
Hi Peter,
Unfortunately windows does not allow you to specify different executing programs between files with the same extension. The link provided above explains how if you have the older version open, it will open in that version, however once you open it in the newer version and save it, you can no longer open it in the older version. Sorry for the inconvenience.
Sappster
(2,398 Views)
