How to avoid the prompt window
i'd like to give a specific adress to this VI. I tried to remove the file dialog fonction and to replace it by string to path vi but it doesn't work. does someone know how to this ? i attached the vi in question.
Best Regards
Tchou
Message 1 of 10
(4,178 Views)
Oups!!!
i forgot to attached the file.
Message 2 of 10
(4,169 Views)
Hello again:
Don't wire an empth path constant instead of a string.  Also you don't need to create a local variable of that output array,  just directly wire it into the for loop.  This way you don't need to specify the number of iterations or wire the interation count to index the array.
Joey Cao
CLD
Message 3 of 10
(4,165 Views)
Message 4 of 10
(4,160 Views)
Message 5 of 10
(4,160 Views)
Hello Joeycao,
i don't really understand what you say. I want this program to go reading to the specific path instead of prompting me everytime to choose the file. i'd like to have constant path.
thanks
Tchaou
Message 6 of 10
(4,157 Views)
Please review the picture I attached, I think you said you tried not using the file dialog vi and wire a string to the input instead.  What I was trying to say was to use a empty path constant instead of a string.
Joey Cao
CLD
Message 7 of 10
(4,149 Views)
i tried to do as you pictured, but it gives me an error because of the close file function. let me tell you that i disable the dialog file function cause i told you that i don't want the program to prompt me a pop-up window. what i want to do is to run the program without a prompt window, which means that i got a constant path.
Regards
Tchaou
Message 8 of 10
(4,140 Views)
Did you right click on the path constant and browse for the path of the file you want to read?
Joey Cao
CLD
Message 9 of 10
(4,134 Views)
Hello Mr joeycao ,
Thank you so much for help and patient. Everything does as i wanted. tanks a lot.
Tchaou
Message 10 of 10
(4,128 Views)
