How to backward annotate from Ultiboard after renumbering parts to OrCAD?
Hi All,
Any helps or comments will be appreciated.
I use the OrCAD V7 as a schematic capture and the Ultiboard V11 for layout. After I finished layout my PCB then I renumbered the parts in sequence Ex. R1, R2 ....Rn.
How do I backward annotate to my OrCAD schematic?
Is there any OrCAD to Ultiboard translator to do the forward and backward annotate out there?
Thanks for your time in advance.
DeanN
(2,500 Views)
Hello:
Backward annotation is only supported when you use Ultiboard and Multisim. In your case, you will need to manually update the changes to your schematic.
Fernando D.
(2,479 Views)
