How to blend moves from two or more motion boards
Can move for multiple axes be blended from two or more montion control boards intalled in the same computer and connected with RTSI cable?
(2,567 Views)
Waterwolf,
You cannot blend the movements together from two seperate boards using "blend motion.flx".  Although, the links below describe how to start a move on two boards at the same time.  Depending on what you want to accomplish, you should be able to have some success using the info in the KBs below.
How to Synchronize Two FlexMotion Boards to Start Simultaneously
How Do I Perform a Simultaneous Multi-Axis Start on More than One Board?
I hope this helps,
Lorne Hengst
Application Engineer
(2,553 Views)
