How to blink a single element in an array of string
Hi Johnsold,
 It seems to be ok, something is better than nothing..:)
I will try this out.
Thanks to all
Hanee..
Message 11 of 16
(1,667 Views)
Hanee,
if you know the number of elements in the array during edit time, you should follow Ian's suggestion and display the elements in a cluster. This will enable you to set attributes for dedicated elements.
The downside of this approach is less scalability of the software.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 12 of 16
(1,656 Views)
Hi Norbert and Lan,
Yeah that is correct I can blink the cluster element one by one. Here the small problem is I can't have vertical scrollbar if cluster has lot more elements. The vertical scroll bar will work only in case of array.
Please find me the way how to enable vertical scroll bar in cluster.
Many Thanks
Haneef
Message 13 of 16
(1,645 Views)
Aha!
Perhaps a better solution for you would be to use a listbox.
The attached gives you the idea. You might need to play around a bit to get blinking rather than just highlighted, and possibly to prevent user mouse clicks, but this shouldn't present too many problems.
Ian
Message 14 of 16
(1,626 Views)
I would use a listbox.
EDIT: looks like Ian beat me (mine is less complicated, thought!) 😄
Message 15 of 16
(1,619 Views)
Here's a version that cycles throught all items, blinking each twice.
Message 16 of 16
(1,607 Views)
