How to bring subvi into keyfocus after loading the subvi and open into main vi?
Hi. How can we bring the sub-vi into keyfocus after loading and opening it into main vi?
regards,
Clement
(2,743 Views)
Go to VI Properties, then Category: Window Appearances
Under "Custom", sets the "Window behavior" to "Modal"
See if this is what you wanted to have 🙂
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,739 Views)
You should note that Modal will force you to close the window before being able to access other windows.
The basic setting you need is Show Front Panel when Opened, in the same screen Ian posted.
If you actually want to get automatic key focus as well, you should create a property node for that control, select the KeyFocus property and wire T into it.
___________________
Try to take over the world!
(2,728 Views)
