How to build a Labview Installer without MAX
I have created a LV program, using VISA.
When I create a Installer, MAX is also included - this is not necessary, how can I avoid it?
Furthermore, how does one deinstall the NI libraries when deinstalling the product? Due to their size this may be desired.
(5,314 Views)
Go to installer properties ->  Additional installers -> un-check  NI Measurement & Automation Explorer.
From controll-panel -> Add remove programs   you can uninstall   NI software.  It will asks which parts to de-install.
(5,284 Views)
Yes,
this sounds very logical, and has been attempted, but:
1: In Additional Installers NI Measurement & Automation Explorer is not checked.
(Only Run time engine, Variable engine, variable manager, visa configuration support and visa runtime is installed)
2: the installation disk created by LV is 200Mb, but the NI programs that are to be deinstalled are of only 4Mb - normally an installation expands on disk instead of shrinking, is the footprint of the NI runtime engine really only 4Mb on an XP machine?
(5,267 Views)
Maybe one of the installer options needs MAX and installs it even when you didn't include it?  I could imagine that VISA configuration support does that, as it's something that is related to MAX.
As for the size of the installation:  The Labview executable is often very small.  The Labview runtime that you need to run the executable tends to be large, especially when you need things like DAQmx etc.
(5,263 Views)
Well, I may need visa configuration support - at least it is suggested by the program (what does VISA config support DO, btw?. I use VISA, but do I need VISA config support?). Both the LV runtime engine and the program developed by me are just a couple of Mb large. I was expecting to be able to deinstall a few hundred Mb of data.
(5,257 Views)
Nobody here who actually know how this works?
(5,214 Views)
