How to build a distributed system with myRIO
Hi all
Can anyone give me a hint as to how the overall structure of the program in LV should be organized if my system is to be operated in the manner described below?
The system is to consist of 5 myRIOs and 6 PCs, with one of them being the master. Namely, it will connect the operator panels of the other 5 and enter its own values if necessary. Meanwhile, each of the 5 PCs is connected to a specific myRIO and can enter values and save data.
In one uncompiled project this is unlikely to be done.
Will LabVIEW alone be sufficient at all for this?
For PC-myRIO communication will Global Variable or Network Streams be the best?
Thank you in advance for your help
(3,501 Views)
See Understanding Communication Options Between the Windows HMI, RT Processor, and FPGA
It depends how what task you want to implement on the HMI (PC) or RT. If the sole purpose of the PC is to serve as a UI, you could use only one host PC to control 5 myRIOs,
https://tmesystems.net/
(3,477 Views)
@spalinowy wrote:
Hi all
I'm not sure what the Question is, as there is a lot of "vagueness" here.  So here are some barely-solicited opinions:
  • The purpose of the "One PC to Rule Them All" is unclear.  Without any idea of the nature of the Tasks, it's hard to say what the "boss" has to do, or why so many "vice-presidents" are required.
  • I don't understand "In one uncompiled project this is unlikely to be done."  What is "this"?  What's with "one uncompiled project"?  What is the "goal" that can't be done?
  • There's nothing in your vague specs that suggest that LabVIEW would not be "sufficient at all for this" (try to follow all those negatives!).
  • I've done several LabVIEW RT projects (some with PXI's, some with myRIOs) and in the few cases when I mixed Network Streams with Network Shared Variables (is that what you meant by "Global Variable"?) is I dropped the Network Shared Variables.
Provide a lot more specific detail, best done with LabVIEW VIs (not pictures, but actual editable/testable code) for less vague responses.
Bob Schor
(3,457 Views)
Thank you for your reply.
1. I haven't developed a multi-device application so far, so I have some doubts and I'd rather ask and discuss before I make a mess and run into a dead end. I have already prepared some programs for cRIO and myRIO, but always for single devices.
The whole system will be for teaching purposes. That is, 1 PC for the instructor to monitor the data, from the stations that the students operate on the other PCs. The only option the instructor will need other than to view the data is to be able to take control of the selected position by entering his own values. Communication is to be done via WiFi.
2. Speaking of an "uncompiled" project, I meant not to create an installation file (EXE), since the project will be developed for a long time, and subsequent compilations and installations only add work. But still, I reckon it may be inevitable.
3. Yes, I also used Network Stream and Network Shared Variables. While I have no objections to the former, the latter is not very predictable. Recently, in a running application, they stopped transferring data overnight. Values were changing in the loop where they were received from the Host, but no longer reaching subsequent loops. I saw that I was not the only one who had this problem. Therefore, I am skeptical about this solution. For me, communication is always to be ensured at 100%, and only data can be transmitted lossy or lossless.
4. My current inclination is to have an HMI embedded on myRIO on each of the 5 PCs, while the handler would have communication with the devices via Network Stream. I just don't know yet how much simultaneous use of myRIO by 2 PCs is possible.
(3,442 Views)
Thanks for explaining the basic "connectology".  Here's my take on it, and my untested "guesses" as to the problem points.
  • Communication between Host PC and myRIO Target.  This is standard every-day LabVIEW RT programming, and Network Streams appears as a pretty robust methodology for both two-way Message Handling (and control) between Host and Target and Target-to-Host Data Streaming.
  • A simultaneous "Supervisor" system running on another PC to monitor/oversee the various Host/Target systems.  I have less experience with these kinds of communications.  There's another poster who is trying to do a similar sort of communication within three routines running on the same PC (as opposed to on three separate PCs) using Network Streams, but then you have the problem of starting and stopping the Professor-Student connections without interfering with the Student's "internal" connection to their myRIO.  One possibility would be for the Student to periodically update a "Status File" (and then close the file) that you could periodically copy to your desktop and "Read All About It" without interfering with their work.
Keep us updated on your progress.
Bob Schor
(3,426 Views)
Some modern options, I now avoid network shared variables and streams.
1. MQTT with the broker on the windows, each RIO is a client. pub/sub as needed to transfer data. Mosquitto can run as a windows service. HiveMQ is good too (need java). MQTT Explorer is a great tool also. LabVIEW MQTT client on github.
2. Web server with HTTP, each RIO has a web server and responds to get/post requests.
3. InfluxDB with Grafana. InfluxDB on the windows, each RIO writes to it. Grafana can pull data out in real time and graph it. For button controls you can implement HTTP and/or MQTT on Grafana. LabVIEW InfluxDB API on github.
(3,366 Views)
I would second these suggestions as well. I am a very big fan of a publish/subscribe model. We use our own library which we developed over 15 years ago. However, with MQTT or HTTP it would be easier since there are several options available to you.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,356 Views)
