How to build and executable which will include Advantech DAQ vi's. Have Advantech USB 4750
I'm using Advantech USB 4750 hardware and Advantech DAQ VIs. It is working perfectly on the developing machine. Now i'm trying to create an executable. cant get the executable to talk to the DAQ. I already installed the USB 4750 driver and runtime engine in the machine I will be running my executable. How do I incorporate the Advantech DAQ VIs to my executable. They are showing as dependancies on the Project exlporer. Need some help on this.
Message 1 of 11
(6,581 Views)
Can you post the project so I can take a look at the build specifications. Thanks
Travis-E
Product Marketer
Message 2 of 11
(6,557 Views)
Did you resolve this problem? I am having the same problem. Please email me. stheron@tellumat.com
Message 3 of 11
(6,532 Views)
Hi, No i havent solved the problem yet. I'm just running it from the development machine. If i findout i will let you know.
Message 4 of 11
(6,525 Views)
Perhaps these vis hook into a dll that isn't being packaged?
Bill
CLD
(Mid-Level minion.)
Message 5 of 11
(6,517 Views)
Thank you.
Please let me know If you find a solution.
I will also install the dev environment, for now.
Message 6 of 11
(6,509 Views)
You can try including the DLLs from the driver in the Data folder that is created when you make the executable. Alternatively you can create an installer and specify the location of the driver you would like to use in the source code area. That way when the driver is called it will have a known path. Here is a document that may help in building an installer with other installers: https://www.ni.com/docs/en-US/bundle/labview/page/including-additional-national-instruments-installe...
Travis E
Product Marketer
Message 7 of 11
(6,492 Views)
I'm having the same issues. The strange thing is, the executable will not work on the development computer either. The VI will run fine. But if I start the executable, then start the VI, the VI shows an error but the executable runs. I really need this executable to be able to be run from a computer without LabView. Any suggestions? Tried to include the project below.
Zach
Message 8 of 11
(6,321 Views)
Hello DiracDeltaForce,
Besides Travis-E recommendations on this post, I wanted to show you these links:
Building an Installer (Windows) - LabVIEW 2012 Help
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/build_installer/
Building a Stand-Alone Application - LabVIEW 2012 Help
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/building_a_stand_alone_app/
Hope you find them useful.
Regards
Ernesto
Message 9 of 11
(6,294 Views)
I have the same problem. When I install DAQnavi it installs DAQnavi Runtime which I think is the problem!
Then it works
Message 10 of 11
(6,094 Views)
