How to build applications from LabVIEW with Diadem?
Dear all,
I got a question regarding a LabVIEW application with integrated DIADEM report VIs (DIADEM Report). My problem is that the computer, on which the application shall run, has no DIADEM installed.
For LabVIEW it is clear to install the RUNTIME engine, which works on PCs without installed LabVIEW, but is there something similar for DIADEM available?
Thanks for your help in advance.
RidderM
Message Edited by RidderM on 01-09-2008 07:39 AM
(2,447 Views)
No, I don't think it is possible.
The LabVIEW VIs call the Activex interface of DIADem, I was also exploring this and the best I could think of is to contact a computer that has DIADem installed to run the LabVIEW-DIADem connection there.
However I didn't ask it to NI.
Ton
My LabVIEW Ideas
(2,437 Views)
