How to bundle a String-pointer into a cluster?
Hi
I have to pass a cluster into a DLL (called by reference). Theres is no
problem, it works.
But, one component in the cluster should be a pointer of a char-array
(String). How can I manage them?
Thanks Mareike
(4,232 Views)
Unfortunately, when you use the Adapt to Type input on a Call Library Node, you are at the mercy of LabVIEW's data types. In this case, LabVIEW will only pass a string and a LStrHandle (a handle to a pascal style string). Look at app note 154 for more on this. The workarounds would be to A)generate a string pointer in some other piece of external code and pass the pointer through LabVIEW as an int32, or create a DLL wrapper function to assemble the struct the way you need it before calling the actual function.
(4,231 Views)
You can use windows function:
lstrcpyn, from kernel32.dll
It takes two string pointers, and gives a string pointer back. Here's the
trick;
Wire the first input with a string buffer, at least the length of the input
string.
Wire the second with the desired string.
The routine will copy the desired string into the buffer, and return (in the
return value) a pointer to the copy.
Make a VI out of this, and make the vi reentrant....
Now you can get pointers to strings, without home made external code.
Wiebe.
"Aaron Marks" wrote in message
news:506500000005000000F3600000-1012609683000@exchange.ni.com...
case,
(4,231 Views)
Yes, it works!
Mareike
"AIR" wrote in message news:a4vlv1$ipi$1@news1.xs4all.nl...
> trick;
input
> string.
the
> Regards,
> Wiebe.
(4,231 Views)
I also facing same problem but i could able to run this i have attached my code here pls give ur suggestion
Message Edited by jaffer on 05-08-2009 09:26 AM
(3,815 Views)
