How to burst multiple pattern(.digipat)
Hi, I have a problem about schedule different patterns(.digipat). Questions are as follows.
  • Digital pattern editor can't do scheduling actions (Fig.1. [1~3]), so I use LabView to implement it. The result is shown in Figure 2, but the results are not as expected.
  • Start label in Figure 2 seems to only specify one of the Pattern files (.digipat) for burst, what should I do to achieve the scheduling function of Fig.1. [1-3]?
Thank you.
ZT
Fig. 1.
Fig. 2.
(3,992 Views)
Can you specify how you expect your burst mode to act?
(3,852 Views)
I  have used Scripts and triggered them as they ran to be able to sequence patterns.
Does that help?
Ben
(3,847 Views)
If you don't care if there is a gap between the digital patterns bursting, then just change the string element you have on your block diagram to an array and enter the three start labels you want to burst as the first three array elements.  Make sure there is a "halt" op code at the end of each digital pattern, and remove the "1" wired to the "N" terminal on your FOR loop since you'll be auto-indexing through array elements.
If you need there to be no gap between the digital patterns bursting (to keep a clock ticking phase-continuously, for example), you'll need to use pattern op codes.  See the Digital Pattern help to see how to do that, but you'll probably want to use a "jump" op code to jump from one digipat to the other.
If you post questions about hardware on the appropriate hardware forums instead of in the LabVIEW software forum, you'll get the best help.
(3,814 Views)
 Sorry for the late reply. I have implemented this function to burst multiple pattern.
 The LabVIEW code like this:
 Thanks each help.
 ZT
(3,794 Views)
