How to calculate Tank level measurement?
I am measuring the tank level using level transmitter, Model=PLNH, range=0 to 1800mmH20, output=4 to20mA, 2wire and other model=SHT-100s
 4mA to 20mA.
How can I calculate the voltage to level?
(2,693 Views)
I am using Ni6251 voltage type DAQ
(2,692 Views)
1800/(20-16) = 112,5mm/mA
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,680 Views)
Please can you explain the measurement method..as the DAQ board can read voltage..
so I should apply the resitance and what is the voltage to level equation.
I could not understand your equation.
(2,673 Views)
