How to calculate impulse response from frequency response data by IFFT??
i want to calculate the impulseresponse from complex frequency-response data.
My problem is, that for the first ten frequnency responses my frequency response
is very bad. But i can´t cut these values out of my complex array coz if i do so the
sampletime doesn´t fit anymore to my frequency response. What can i do??
greetings,
RRapha
(4,529 Views)
Hello RRapha,
do you use the Impulse Response Function PtByPt.vi?
In that case, it might help to modify that VI to use the Cross Power.Vi instead of Cross Power PtByPt.
Johannes
AE, NI Germany
(4,515 Views)
