How to calculate mean of 1D array?
Could someone please help me, how could I calculate mean of 1D array? For example, if the 1D-array is [2, 3], I would get mean = 2,5. Thank you very much!
Message 1 of 8
(34,126 Views)
Accepted by topic author framboise1
Use the mean function. You can use the search or quick drop to look for it in case you don't know where to find it.
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(34,115 Views)
Thank you for your answer! For some reason, the mean function doesn't work properly. Could you please check in the picture, where the problem could be?
Message 3 of 8
(34,110 Views)
remove the FOR loop on trhe right. It does not belong there.
Message 4 of 8
(34,098 Views)
Thank you for your answer! If I remove the FOR loop, for some reason it gives me NaN output. Input is 1D array and it looks as it should ([1, 2, 3, 2, 1, etc.]).
Message 5 of 8
(34,093 Views)
Please post your VI. The image is not sufficient to understand what you are looking for.
NaN is "not a number" which means that you have invalid elements.
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(34,077 Views)
So assuming you are beginner in LabVIEW,
-Create New VI
-Place array constant/ Control and keep numeric constant inside it.
-Now enter 2 and 3 in array
-And then use mean vi: http://zone.ni.com/reference/en-XX/help/371361M-01/gmath/mean/#parent
-Now if your mean output is not 2.5 then mean function is not working correctly ok?
-If the array is empty also you would get NaN.
uday
Message 7 of 8
(34,064 Views)
Thank you very much for your help! I found the problem (as you said, it was in the input) and now the mean function works properly! 🙂
Message 8 of 8
(34,050 Views)
