How to calibrate NI9237 used with CRIO 9073
I am using NI9237 with CRIO 9073,i wanna do calibration and offset correction for Ni9237.There is a pdf for the same with CDAQ (http://www.ni.com/pdf/manuals/372306b.pdf).
Pls help me on how to do the same with CRIO.
(3,135 Views)
Hello krupa,
with the FPGA interface you have some properties for this
NI 9237 (FPGA Interface)
Use a I/O property and select the channel and then the function
In the LabVIEW Example Finder search for 9237 there is the NI 9237 Getting Started.lvproj which include this.
best regards
Alexander
(3,074 Views)
