How to call Labview-VIs in a AgilentVee-function?
i have some good running Labview-Vis and want to use them in a Agilent-Vee-function (*.vee).
Is there a way to make a DLL from the VIs?
Or is it possible to run a VI from a C++-DLL? Then i could create this DLL and call the DLL in VEE.
But i would be easier if i could call the VIs direct in VEE, so if any VEE-users are reading this... perhaps someone has an idea.
Thx for any ideas.
best regards
J.
Message 1 of 19
(5,680 Views)
Hi J.,
you can create DLLs from your VIs using the ApplicationBuilder (but you need a proper license/LabView version). Which version do you use (number and kind [base/full/professional])?
Maybe you should ask the same question in an Agilent/VEE forum?
Message Edited by GerdW on 06-11-2008 10:48 AM
Message 2 of 19
(5,679 Views)
Or you could use the VI server ActiveX interface to do this.
Ton
My LabVIEW Ideas
Message 3 of 19
(5,672 Views)
I´m using LV Professional 8.5
The Homepage says that the ApplicationBuilder is included "Included as part of the LabVIEW Professional Development System":
https://www.ni.com/en-us/shop/product/labview-application-builder-module.html
But where can i find this program?
But could to hear that there is a way.
Message 4 of 19
(5,671 Views)
Hi J.,
you have to use the project explorer to be able to build apps/dlls/distributions. In the project you have a (virtual) folder named "Build Specifications" where you create your spec for making a DLL from your VI.
Maybe you should read the manual or attend one of the (free) online courses for LabView basics?
Message Edited by GerdW on 06-11-2008 11:32 AM
Message 5 of 19
(5,661 Views)
In the VEE-directory is an example how to do this.
Located in:
C:\Programme\Agilent\VEE Pro 7.5\examples\ActiveXAutomation\LabVIEW.vee
Message 6 of 19
(5,640 Views)
The LABView.VEE example doesn't work.
Message 7 of 19
(5,279 Views)
Ok. And this is a 6 year old thread…
Did you ask Agilent for support? It's their software and probably their example…
Message 8 of 19
(5,274 Views)
Thats an old thread.
Of course I contacted Agilent first because it is their example with a disclaimer posted at the top. I also contacted NI and they were very willing to try to explain their Active X interface and how it might be utilized to invoke NI Vis. I am getting closer, but I have still not been able to invoke my *.vis built as a *.llb and exposed to Agilent Vee via the Active X Automation interface.
The feature of this interface is the protocol is ellusive, at least to me. I have even turned to some C/C++ examples, and C# examples trying to gleen protocol information. I'm closer but not their yet.
So... does anyone have a working example of invoking Agilent VEE invoking a NI vi (*.llb), via an ActiveXAutomation interface.
I am usinmg Agilent Vee 9.3 PRO, LabView 2013.
Message 9 of 19
(5,268 Views)
An llb is not a VI. It is an obsolete way to store VIs and should not be used. Try calling a VI that is outside an llb.
Message 10 of 19
(5,264 Views)
