How to call MATLAB function from LabVIEW's 'MATLAB Script'?
I have a MATLAB m-file as follows:
testfcn.m
function [A,B] = testfcn(C)
A = log10(C);
B = C.^2;
How can I call this function testFcn from a MATLAB Script in LabVIEW? See pleaseHelpMeMakeItWork.vi for an illustration of the problem. The attached vi x`attempts to run
Attempted Script Node Code
It does not work. I get
So, ehrm, what the heck here? For context here is the code location on my machine -
This testfcn() works just fine in MATLAB, see example_working.m. But like, how to use it in LabVIEW?
  • I attached the VI pleaseHelpMeMakeItWork.vi which was mentioned above.
  • For the example MATLAB file testfcn.m it is posted as testfcn.txt because forums.ni.com refused to accept a *.m file... 🙂
 Important Context
The answer 'just cut and paste your sub-routine into the script, no function calls needed'  doesn't count either... 🙂
justinmreina@gmail.com
(12,448 Views)
An anwser may be here -
    MathScript Nugget #10: How To Call User-Defined Functions
But from what I see here this requires MATLAB RT (Real-Time), so this does not apply as a generic solution?
(12,406 Views)
Another solution may be found somewhere within here:
http://www.ni.com/white-paper/7006/en/
(12,394 Views)
Keep in mind, you're essentially saying "See!  My m-file exists right here!  It exists!  How can LabVIEW not see it!?"  What steps have you taken to help LabVIEW see where it is saved on your machine?
(12,000 Views)
Hi
Some kind of late answer.
You need to add the path of the function in the matlab script.
Add this on top of your matlab script:
path(path, 'function's path');
(8,482 Views)
