How to call a python function with a filename parameter
I have been given a python function whose parameter is a filename.
How do deal with the filename when the file data type is not supported?
I believe this is a common use case.  Basically I just need to know how to call a python function with a filename parameter.
I have tried to use a string (see code example below), but to no avail.
I get Error 1667 occurred at Python Node in MyString.vi->Call MyString.vi
Python code
import math
import numpy as np
from pathlib import Path
def load_my_file(my_string):
"""Loads a file and returns the name."""
    filepath = Path(my_string)
    return my_string
From Help >>>>
Python Node Details
Supported Data Types
The Python Node supports a large number of data types. You can use this node to call the following data types:
  • Numerics
  • Arrays, including multi-dimensional arrays
  • Strings
  • Clusters
  • Booleans
(967 Views)
LabVIEW node Path To String. That's it!
Rolf Kalbermatter  My Blog
(941 Views)
Thank you.  I will check that out.
(887 Views)
