How to call visual basic exe file from LABVIEW 7.1
Hi all,
I would like to call a visual basic 6.0 application(executable file) from labview 7.1 kindly anyone is having code or papers send me.
Thanks and Regards
rajesh
(4,545 Views)
Use the System Exec VI from the communications pallette. You can call any executable.
___________________
Try to take over the world!
(4,540 Views)
Hi
could you please suggest me where this vi is present in labview ?
Regards
rajesh
(4,537 Views)
Rajesh
Attached bitmap shows where to find the System Exec.VI
(4,528 Views)
Hi all,
i would like to run a visual basic programme from labview , i have attached my file , even though iam executing the programme iam not able execute the vb file , kindly suggest me ,
Regards
rajesh
(4,517 Views)
Rajesh,
I'm not sure I understrand exactly what you're trying to do. It looks to me like you took a powerpoint object and just renamed it. I'm not a VB or VC programmer, and I don't work much with activex, but I'm sure this can't work. I think you have to register an ActiveX object before you have it in the list and that you have to export its properties and methods correctly and specifically for it to work.
Why not use the system exec VI?
Do you want to get data back from this program? Maybe you can build it as a DLL and call that from LabVIEW.
___________________
(4,507 Views)
