How to capture a live image(through USB) in labview and split it into frames?
Message 1 of 8
(4,812 Views)
ActiveX
Message 2 of 8
(4,808 Views)
IMAQdx
Message 3 of 8
(4,803 Views)
Make sure to install NI-IMAQ for USB before you try anything!
http://zone.ni.com/devzone/cda/epd/p/id/5030
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 8
(4,789 Views)
I have already installed imaq usb .. but even though i am unable to access features like IMAQ USB Close.vi,IMAQ USB Open.vi,IMAQ USB stop.vi, IMAQ USB Grab acquire.vi, etc. I am using labview 2009 in windows 7 environment. PLease help...
Message 5 of 8
(4,739 Views)
Do you mean you don't see the 'IMAQ USB' palette?  It should be right in 'Vision and Motion'.
Message 6 of 8
(4,718 Views)
no sir .. i am unable to see the usb palette.. instead.. when i am opening an example vi ... the usb palette components are not getting loaded...
please help sir!
Message 7 of 8
(4,712 Views)
Hmmm.  There are many messages at the bottom of the driver link I gave you (above).  It appears that a lot of people are having problems getting this to work.  NI doesn't officially support these drivers but I think you need to try contacting tech support anyway.
I've had no issuses installing or working with these drivers but I'm using LV8.5 on winXP
Message 8 of 8
(4,707 Views)
