How to catch USB device plug/unplug events
I'm working on a LABView/C# solution for production test system of a USB device. When LABView code finishes running a numbers of tests on a USB device, the device is unplugged, a new one is plugged in and the LABView repeats the testing. The underlying C# framework has a limitation that requires LABView code to call a function in the C# framework before the new USB device can be communicated with.
How can I do this?
I tried using the Window message queue library (http://zone.ni.com/devzone/cda/epd/p/id/4394) but it seems to be able to catch the WM_DEVICECHANGE only (twice for each device swap), never DBT_DEVICEARRIVAL or DBT_DEVICEREMOVECOMPLETE. I could count the WM_DEVICECHANGE to decide that a swapping has completed, but it is not the best technique.
I also got the error (shown in the attached picture) unless I set a breakpoint in the Message Queue library to make LABView stops there before going on.
I read something about one need to register for DEV_BROADCAST_DEVICEINTERFACE notification but don't know how to do that in LABView. Or how could it be done in a C# library so LABView can invoke?
Please help.
Tuyen
(6,989 Views)
Hi tuyen,
i have some code running in delphi which detects new devices like usb stick. It shows the assigned drive letter which with you can work with.  I'll try to build a labview example for you at weekend.
Mike
(6,943 Views)
Hi Mike,
That's great, thank you very much. I'm looking forward to see the code.
Tuyen
(6,926 Views)
Hi Tuyen,
Hope this helps you.
(6,915 Views)
Hi tuyen,
i had some time to write the example. It works with windows messages. Attached you'll find it. The Main vi is the "DeviceChangeEvent_Example.vi".
Hope it helps.
Mike
(6,865 Views)
