How to cause an internal trigger to generate a pulse on an Oscilloscope
I am realtively new with LabView and need to generate a square pulse on an oscilloscope. I am trying to cause a trigger such that only when it is triggered, the pulse is generated. What should I do to get such a trigger?
Thank you.
(2,604 Views)
A score does not typically have the ability to generate any sort of signal. You have not mentioned the male and model. Where in its manual do you see pulse generation?
(2,598 Views)
