How to change Agilent B2901A "measure speed" via Labview
I am new to Labview and I am trying to control Agilent B2901A via Labview program. But I can not find the option for "measure speed" in Labview, this have bothered me a few days.
Thanks in advance!
(1,094 Views)
Hi John,
Did you read the manual of your SMU? There you will find the information you are looking for…
I guess you will need to use one those two options:
  • reduce the accuracy of the readings to improve sample rate
  • use some internal buffering to improve sample rate (as long as sufficient memory is available)
(1,064 Views)
Accepted by topic author johndoin
Thank you Gerd,
Yes,I have been reading the manual and looking forward to find an option to change it.
Actually, I want a long measure speed to improve the accuracy. I will try your suggestion.
Thank you again
(1,048 Views)
