How to change Color of the Text Selection?
Colleagues,
Pretty simple question about control's customization. How to change the color of selection? By default it inverted and appeared black:
What I need is something like that:
Strange I haven't found any suitable property... Smiley Sad  Is it possible, or I wanted too much from LabVIEW?
Andrey.
(3,174 Views)
I think this is a function of the OS. In Windows, the selection background color seems to be the complement of the normal background of the selected text.
I've seen several references to this, but can't find an authoritative link at the moment.
I tested it with this quick VI... (LV 8.6)
(3,162 Views)
I don't think you can customize it. By default it is the inverse RGB color. If the string background is yellow (RGB 255,255,0) then the selection will be blue (RGB 0,0,255).
The same apply to the selected text.
Ben64
(3,161 Views)
Thank you.
You're correct - this is inversed color depends from the color of background.
It can be changed in Windows Settings and works, for example in WordPad (and in Notepad as well):
But no effect in LabVIEW (also no effect, when System String used instead of Modern).
This probably will work for RichText or similar system component from OS, but using ActiveX or .net control for every string - no, thanks...
(3,154 Views)
And what is funny - it works for Rings, Enums, etc:
But not for Text Selection.
(3,145 Views)
