How to change IMAQ image display position on FP programmatically?
Hi All,
I need to change the IMAQ image display on FP programmatically.  I check the property node and find out it is read-only. Is there a way to do that?
Thanks a lot for any help.
Anne
(2,897 Views)
Hi Anne.
Maybe you solved it in between.
The "Position" property of an ImageDisplayControl is not read-only. You can set the property at tun-time.
Regards, Guenter
(2,868 Views)
Yes. Problem sloved.
Yesterday I picked up the wrong property node.
Thank you.
Cheers.
Anne
(2,866 Views)
