Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to change IMAQ image display position on FP programmatically?
Anne Zuo
Member
04-29-2008
06:08 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi All,
I need to change the IMAQ image display on FP programmatically. I check the property node and find out it is read-only. Is there a way to do that?
Thanks a lot for any help.
Anne
0
Kudos
Message
1
of 3
(2,896 Views)
Reply
Re: How to change IMAQ image display position on FP programmatically?
GuenterMueller
Active Participant
04-30-2008
06:12 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Anne.
Maybe you solved it in between.
The "Position" property of an ImageDisplayControl is not read-only. You can set the property at tun-time.
Regards, Guenter
0
Kudos
Message
2
of 3
(2,867 Views)
Reply
Anne Zuo
Member
Author
04-30-2008
06:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes. Problem sloved.
Yesterday I picked up the wrong property node.
Thank you.
Cheers.
Anne
0
Kudos
Message
3
of 3
(2,865 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
