How to change Julian date string to Normal Date string
I need to change a Julian Date code (string format) to a Normal Date code (string format).  This is not in real time so using Get Date doesn't seem to be the solution (unless someone else has a way to do this).  I am reading a scanned in date in the format:
YYDDD
and would like to change it to:
YYMMDD
Is there a quick function or easy way to do this?
Thanks!!
-ncm
Message 1 of 8
(7,536 Views)
Accepted by topic author ncm
Scan from string followed by a format into string using the right time codes for the format strings.
Message 2 of 8
(7,520 Views)
I was drawing up code for this question and came up with the same solution expecting for it to work but I get a totally different answer.
aputman
Message 3 of 8
(7,506 Views)
The issue seems to be related with the LV version. Running your code in LV2014 gave me the same result as RavensFan, running it in LV2012 gave me the same answer as you.
Ben64
Message 4 of 8
(7,502 Views)
I remember this "feature", I think if you try '0015123' in LV12 it works.
Message 5 of 8
(7,492 Views)
Sure enough.  That's a "useful" "feature".
aputman
Message 6 of 8
(7,487 Views)
That brings back memories.  I had come across a bug in LabVIEW 2012 that was related to time stamp codes and 2 and 4 digit years.
See http://forums.ni.com/t5/LabVIEW/Scan-from-String-to-get-Timestamp-Problem-in-LV-2012/m-p/2774248#M81... where it talks about CAR300375
Message 7 of 8
(7,472 Views)
Thanks everyone!  All answers were helpful, I am using LabVIEW 2010 so I needed the additional "00" in the front as well.
-ncm
Message 8 of 8
(7,413 Views)
