06-03-2013 06:08 AM
Hi, I have experience in Dasylab, and I know that it is possible to change measurements in the graphical readings . What I want to do is to convert voltage readings to pressure (either PSI or PA- preferrably PA). Does anyone know how to do this? Thanks
06-03-2013 08:11 AM
I see an Express VI for scaling. It's simpler than DASYLab, but does offer y=mx+b, and a table of reference points.
There was an example using it, too, when I searched for examples.
06-03-2013 08:22 AM
Making conversions such as this should be device dependent. Check the manual of your gauge to determine the responsivity (Voltage / Pressure). If it's linear, you can accomplish the conversion with some simple math. If it's non-linear, you may have to utilize a look-up table or reference file which contains the conversion factors. Alternatively, if you are using a force gauge, you will also need the device area to convert from force to pressure.
06-04-2013 11:31 AM
Thanks CJ_Butler. I take it you are referring to the Formula (Signal Express VI)? Also just wondering if you or anyone else knows a formula for converting voltage to Pascal (pressure)? Thanks
06-04-2013 11:35 AM
As I mentioned before, the actual conversion you have to perform is device dependent. One may be linear with 1V/1Pa with another being 0.113V/20Pa or perhaps quadratic with PA = 0.002+0.1V-0.0009V^2. There is no universal answer we can give you. If you tell use the device you are using to measure the pressure, we can try and help further.
06-04-2013 11:37 AM
hi, thanks pjr1121 i am using force-pressure sensors
06-04-2013 11:40 AM
Ok, now what specifically are you using?? who did you buy it from? what model number? is there a manual?? Force pressure sensors vary from measuring the weight of semi-trucks to using peizo electrics to measure near nano-gram resolution of very small items.
06-04-2013 12:11 PM
I am using the Force Sensitive Resistor - Square, (from "CoolComponenets") the link for it is below
http://www.coolcomponents.co.uk/catalog/force-sensitive-resistor-square-p-566.html
I have also provided a link for the manual below. The information of the square FSR is on page 12
https://www.sparkfun.com/datasheets/Sensors/Pressure/fsrguide.pdf
Thank you
06-04-2013 12:28 PM
How are you sensing the pressure? That sensor just just changes resistance. I would suggest the Voltage Divider given on page 18 of that guide. You can then work the equation to have the FSM = X (I don't feel like doing the math right now). From there, you know the conversion from resistance to pressure. Combine the equations to go from output voltage to pressure.
06-04-2013 01:37 PM
I'm not particulary goodat Maths..can you pleasetell metheequation, when you areready. Thanks
