How to change Y axis orientation (left/right) programatically?
I am using a xy-graph and want to change the side of the y-axis (left or right) programatically.
Manually, I can do it by clicking on the y-axis in the frontpanel and switch the y-axis on the other side.
Is there a property node to do this programatically?
Thanks a lot an best regards.
Michael
(4,160 Views)
Hi Michael,
I cannot find a suitable property in a quick search.
So you better post that topic as new idea in the idea exchange - among a lot of other ideas for improving the LabVIEW graphs…
(4,154 Views)
one steamroller work around is to create two diagrams at the same position and hide the one you don't need.
Greetings from Germany
Henrik
LV since v3.1
(4,147 Views)
