How to change a value with reference if inside of a tabControl?
i have a Vi with a tabcontrol and two pages. On each page is a string-control (string1 and string2).
Now i have second vi that gets the file-reference of the first vi and is called inside of the first vi.
This reference do i want to use to change the value of the string-control.
But i dont have access to "pages" when using the reference.
Attached the two vis.
Thanks for the help
Message 1 of 9
(3,511 Views)
I'd do it like this:
Jim
Message 2 of 9
(3,492 Views)
@OnlyOne wrote:
[...] But i dont have access to "pages" when using the reference.
You can do this to address this problem.  Convert the generic reference to a TabControl to get the TabControl-specific properties.
Jim
Message 3 of 9
(3,475 Views)
Thanks for the help.
But how can i create this TabControl-Reference?
I do it like:
1. Create a reference from the TabControl
2. Create a constant from this reference
its working, but the text of the constant is "TabControl (strict)".
Message 4 of 9
(3,457 Views)
I just showed a small part of your original diagram; you don't need to create a reference.  Here's the whole thing (after executing Clean Up Diagram on your VI).  I prefer my solution in my original response over this one, though.
Jim
Message 5 of 9
(3,450 Views)
Yes, i understand that. But my question is: how can i create thie green TabControl for the typecast (which is shown in your picture on the upper right side)?
Than you
Message 6 of 9
(3,445 Views)
Easiest way that I know is to right click on the control itself and select "Create->Reference".
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 9
(3,435 Views)
Oh, ic.
You can pull a Class Specifier Constant out of the Application Control pallet, or right-click on the To More Specific Class target class terminal and create one.  Click on it and browse through  to the type you need:
Jim
Message 8 of 9
(3,432 Views)
Btw, that's not a reference to the Tab Control, it's a type specifier that tells the To More Specific Class what type of object to convert the reference to.  The conversion will fail if the reference isn't for a Tab Control, and you'll get an error.  That's how I found the Tab Control in the Controls[] array in the original answer - I know that there's only one Tab Control on the panel so I continue iterating if I get the conversion error.
Jim
Message 9 of 9
(3,429 Views)
