How to change back a labview file version
I have a Labview 2018 SP1 and the only labview version I use until I install a labview 2019 and run another file , then I uninstall Labview 2019. Then when I want to open a 2018 labview file from before, it says my version is wrong, the file is 2019 version. how can I convert it back to 2018?
(2,855 Views)
Hi pulse,
use the Version Conversion board to ask for downconversion!
(2,831 Views)
Accepted by topic author PULSE.Wannabe
At the time you had both LabVIEW 2019 and 2018 on your computer, any file (of whatever version 2018 or 2019) you open with LabVIEW 2019 and save will have its version changed to 2019, and cannot be opened (any more) in 2018.  If you did this "accidentally" and want to "fix it" before deleting LabVIEW 2019, you can open it in 2019 and then choose "Save for Previous Version", choose LabVIEW 2018, and save it.
I'm also a little worried when you say "I uninstall LabVIEW 2019" (note the correct spelling of LabVIEW).  Installing (and especially unininstalling) LabVIEW can be challenging.  Unless you are very short of disk space, I would have advised you to leave LabVIEW 2019 installed, just delete the shortcut icon from your Desktop so you don't "accidentally" run it and save LabVIEW 2018 code in the "wrong version".
An even better idea, particularly if you are doing serious program development, is to use some form of Version Control System.  For example, just before you open your program in a newer version of LabVIEW, Commit it, and tag it as "My Code just before migrating to LabVIEW 20xx".  Now you can open in the new version of LabVIEW, make some changes to incorporate new featujres or whatever, and Commit with a note "First Commit with LabVIEW 20xx+1", or, if you're not sure and just want to try out a newer version, make a Branch for the new code.  Now you have Your Cake and can Eat It, Too.
Bob Schor
(2,790 Views)
I see , just tried it and it works , thanks so much
(2,721 Views)
