How to change bit in U32 depending on state
how can this be done:
For example:
U32_In is: 00000000000000000000000000000000 (32x 0)
I32_Number: 4
Bool_State. True
Then U32_out should be 00000000000000000000000000010000
Thanks for help
Message 1 of 13
(4,345 Views)
Just use the boolean OR function to bring in that type of logic.
Norbert
Norbert
Expert: Geometry
Message 2 of 13
(4,341 Views)
Simple way: Number to boolean array, replace array subset, boolean array to number.
More efficient way: Bit shifting (shift left, put in your 'True' and then shift right)
Boolean Logic way: Use your new number to create a bit mask and logic AND with the U32
(blog)
Message 3 of 13
(4,339 Views)
Sorry for nitpicking, but
Waste of performance
Helps only for numbers which already have the correct pattern but the pattern is in the wrong location. Btw: Bitshifting is a multiplication or devision (depending on the direction of the shift) by two. So if the result should NOT be a value which is a multiplication/devision by 2^n, this won't work!
AND is the wrong combination. The correct one, as i understand the original question, is OR.
Norbert
Norbert
Expert: Geometry
Message 4 of 13
(4,334 Views)
Ok, the AND makes a 1 at the position.
But how to make a 0 at the specified bit-position?
Message 5 of 13
(4,331 Views)
Re-reading the original question, i have a hard time to understand the desired pattern.
4 in binary would be 100, not 10000, so it seems to require a boolean OR then shifted TWO BITS to the left.
Norbert
Norbert
Expert: Geometry
Message 6 of 13
(4,327 Views)
The 4 stands for bitnumber four. Starting with index 0 it is at position 4. Thats what the 10000 stands for.
The boolean whould then switch this bitnumber 4 to 1 (true) or 0 (false).
Message 7 of 13
(4,318 Views)
Yes, the number/boolean array is inefficient, but it's also the easiest to understand exactly what's happening to a novice programmer.
You were right about needing to OR though - I haven't had enough coffee yet this morning!
As for the bit-shifting...sorry, I meant rotate with carry...you can do that as long as you hold the bits you pull out and then put them back again. You rotate right (storing the bits), and then rotate left inserting your new bit and then the remaining bits that you pulled out earlier.
I was merely proposing that there are a number of different methods for achieving the same thing.
Also, what he wants is to replace the 4th bit from the LSB, not replace it with a binary 4. Needs to use a mask of 2^4, not 4.
(blog)
Message 8 of 13
(4,316 Views)
That kind of operation is best done with using the Logical Shift. Connect a constant 1 to the x input, the I32 numer of bits to shift to y and you get your bit pattern output. Then if you want to change the bit in an incoming integer you have to use different boolean logic depending if you want to set or clear that bit.
To set it you simply OR your input number with the bit pattern, to clear it you AND it with the inverse (Invert node on the Boolean Palette) of the bit pattern.
If the shift (your number 4) is constant and does not need to be parametrized you can also replace the Logical Shift through a fixed numeric constant of in this case hexadecimal 0x10 or decimal 16.
Rolf Kalbermatter  My Blog
Message 9 of 13
(4,310 Views)
@Sam: Yes, i had a misunderstanding on that point. I thought the OP wanted to combine the numbers, not specifying a bit to switch to the boolean value.
Attached a solution i think does what the OP wants (despite i very seldom post "working" solutions!).
But i would expect altenbach to come up with a far better solution 🙂
Norbert
Norbert
Expert: Geometry
Message 10 of 13
(4,301 Views)
