How to change boolean array to ascii or send as bits
Hi everyone,
I am using a RS232 to connect to a microcontroller.  I am using VISA to send the data.  Sorry if I'm not clear enough as I explain this but I have multiple boolean arrays set as controls and I'm having trouble sending the data to the microcontroller the way that I want to.  I'm pretending I have a grid on my front panel in which a chip will be placed on.   So I am only paying attention to the corner boolean buttons.  So if the setup was
101
000
001
 then I would want the output to be "1101" reading from left to right and top to bottom.  Now if I send the data as "1101" to the microcontroller, it is sending it as 32 bits as opposed to 4.  So, I was wondering if there was a way to send the 4 bits as 4 bits, or if there was a way to convert those bits into ASCII before sending it into VISA write seeing that I don't want the micrcontroller to look at 32 bits.
Thanks very much and I'll clear it up if I'm being confusing.
(4,160 Views)
The smallest amount of bits you can send is eight, i.e. one byte.
You could send one byte and define that you want the four low-order bits, ignoring the other four. For this you would first make a boolean array with four elements, then use "boolean array to number", covert to U8 (or set the output configuration to U8), followed by typecasting to a string.
(4,146 Views)
