How to change color of chart's border and sweep line?
I'm trying to do something simple, but I can't seem to find the appropriate properties, even after much experimentation.  I have two "Chart" controls that I have set to "Sweep" update mode.  I want to dynamically change the color of the sweep line that moves left to right as data is displayed, as well as the background color of the entire control (not the plot area).
Because this simple question can be easily confused due to terminology, I have attached a JPEG illustrating what I'm trying to change.
Any pointers?
Thaniks!
-Bob
(4,104 Views)
Hi Bob,
Unfortunately, you cannot change the sweep chart vertical line at this moment in time.  I would highly suggest you file a product suggeston here.  From there, R&D will look at your suggestion thoroughly.
Nadim
Applications Engineering
(4,071 Views)
Hi Nadim,
Thanks for the response regarding sweep line; I'll do so when I get a chance.
Do you know how to change the border?
Take care,
-Bob
(4,066 Views)
Hi Bob,
One way to change the color of the border you are talking about is to use the Set Color Function in the Tools Palette.  I have attached a screenshot as to what I am talking about.
I hope this helps,
Nadim
Message Edited by Nadim R on 05-10-2007 04:41 PM
(4,046 Views)
Sorry, but I need to do it dynamically - any ideas?  I just can't seem to find the correct property!
(4,036 Views)
I have been looking for a property node that controls what you are talking about, but I was unable to find it.  I think one possible workaround is to use a transparent color for the border to the plot and add some sort of diagram color box around the plot.  That way, you will be able to control that color box around the plot.  I would again highly suggest a product suggestion.
I hope this helps!
Nadim
(4,005 Views)
