How to change installer to have the opportunity to install the same program as a new product?
Hello! I created distributive for my project and installed it. Now I want to install this program with fiew changes in code, but as a new product. But new program replaces old one. How to change installer parameters to create a distributive that gives opportunity to install this program as a new product without updating old program?
Thanks.
(3,827 Views)
The easiest is to copy the installer settings (right click, copy).
Ton
My LabVIEW Ideas
(3,818 Views)
Hi. I didn't understand, what do you mean. Even if I rename the installer the new installed program with new name replaces the old one with other name. (I have Labview8.5).
(3,800 Views)
Accepted by topic author BPS
You need to duplicate Installer:
As result the new GUID will be generated, and you will get new product
Andrey.
(3,782 Views)
Hi! I have successfully created the second istaller that installs program as a new product. Thank you for your help! But I didn't understand what exactly I need to change in installer properties to create it without duplicating (or if I want to create an installer from the copy of original project)?
(3,771 Views)
Each installer (on Windows) is identified by a GUID, this is hidden in the LabVIEW project file, by duplicating a installer you create a copy with a different GUID.
Ton
My LabVIEW Ideas
(3,767 Views)
Thank you! I resolved my problem.
(3,760 Views)
