How to change label of a cluster
Hello
Is it possible to change the Label of individual cluster elements
I am trying like this
in my program i will have a set of labels assigned like Alphabets & Numerics
from the combo box if i select Alphabets the cluster elements (LED) label should change to A B C D..
If i select Numeric label from the combo box the labels of the cluster elements (LED) should change from A B C D.. to 1 2 3 4...
How to do this
thank you
sasi
I am using LabView 7.1
(3,652 Views)
You can use the label property of the cluster property node.
(3,645 Views)
If you get the output error on the property node, you'll see that error 1073 comes out because the "label" is readble only.
What you can do is change the caption like shown in the exemple attached.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,643 Views)
Use caption instead of label in visible items for the control/indicator
Label cannnot be changed using a property node, whereas a caption can be changed programatically
(3,637 Views)
