How to change listbox values during run time
      In the below attached VI.Iam using a listbox which has some values and displaying that listbox values in an array.I can change the listbox values and that change can be viewed in the array.But my aim is to change the values during runtime itself.That is without stoping the VI we can change the values in the listbox and that change has to be reflected in the Array.Can we change it using the property node?please share some suggestions.
Thanks.
Thanks as kudos only:)
(4,099 Views)
Hi danil,
select one listbox entry by clicking on it once. Then wait for a second, then click again: now you can edit that entry...
Well, if you would have searched for "listbox edit" here in the forum you would have known that easily too...
Don't forget to include a wait function in your example VI - and also don't forget to initialize the shift register!
(4,087 Views)
Accepted by topic author danil33
right click on your listbox and check mark it "editable cells." at run time..click on cell you want to change, then wait a second and click again...
(4,069 Views)
(4,065 Views)
        Thanks for all the suggestions.
(4,057 Views)
If the click, wait, click is too slow, there are some workarounds like setting the edit cell property. Search for it on the forums. It will allow you to only click once
(4,048 Views)
