How to change local variables in sequence structures
Hey guys,
I am very new to LabVIEW and I have already tried searching this question on the forum but could not find anything related. You patience and help is greatly appreciated.
I am working with an example VI (attached below) that creates a digital output and all I want it to do is to generate a 0 or a 1 every other frame in a flat sequence structure. In other words, the VI can continuously generate a single output but I want it to switch back and forth according to the sequence.
My approach was to make "Data to Write" a local variable and write it in every frame but this does not work, what should I do? Again, I am very new to LabVIEW so please bear with me. If you could attach a simple image to work this out, I would greatly greatly appreciate it. Thank you all very much
Message Edited by diishen on 05-27-2008 04:16 AM
(2,734 Views)
Hi diishen,
you can use a shift register. Connect a boolean constant to it and use a not inside the loop. convert the boolean value to a number and you get your 0 or 1.
See the attachment.
Hope it helps.
Mike
Message Edited by MikeS81 on 05-27-2008 11:24 AM
(2,728 Views)
Hey Mike,
Thank you for the fast response! I've never heard of the shift register before, I will look it up now, can I do the same to start and stop the VI? So say, one frame would turn on the output while the next turns it off?
(2,724 Views)
Hi diishen,
diishen wrote:
... So say, one frame would turn on the output while the next turns it off?
yes, i think the example shows exactly that.
Mike
(2,717 Views)
