12-01-2003 02:09 AM
12-02-2003 02:04 PM
07-12-2007 04:39 AM
Are you still interested in TLE programming and automation?
There is no line number on the tle in the automated test mode since you perform line monitoring and connection based on the detected digits.
e.g. you've got reports from com port that someone dialed 1 - 0 - 4 on the first line. Than you should issue command to TLE to connect 1-st and 4-th line.
To change number assigned to the 4-th port 104 to 5554 just change this behaviour and make switch if "5554" sequence was observed (and reported by firmware through com port).
This can be done in script uploaded to the TLE.
If you have teltone TLE 5 (TLE-A-01) please contact me - I know some tricks with it und have some interesting knowledge.
05-30-2008 05:16 AM
Hi Phasm
I also face the problem for Teltone TLE using by LabVIEW. Basically, in the TLE instrutment driver, it also set the command or action to the TLE(i.e Input). However, how about to receive the signal from TLE. For example, how to detect the number of rings?? What is the voltage or dbm in the current status??
Steve
05-30-2008 06:01 AM
