How to change the 2D array's size of a picture
Now ,I need to change the size(the real pixel size , not the size shown in front pannel).
I have two method, one is to use array modules , one is to change the size of the 2D array, the other method is to resample the picture when reading it . But , each method is difficult for me ,I can not find the blocks from Labview back panel's modules.
I had also seen the page https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Ko3SAE&l=zh-CN,but nothing is done, because there are so many blocks ,(灬ꈍ ꈍ灬) .
any suggestion will be appreciate .
(3,058 Views)
what have you tried?
https://en.wikipedia.org/wiki/Image_scaling
e.g. leave out every third row (shrinking)  or repeat every third row (expanding) of your input image?
(3,022 Views)
I gave up, instead I use PS
(2,478 Views)
Accepted by topic author alii001
(2,466 Views)
