How to change the Max limit in the Ring
 Hi all,
 I am try to use a Ring to set up 4 different of Freq form 18Hhz to 20Ghz but the ring Max limit only 65535. How could I change the max limit? Or any way we could set up 4 diffirence Freq number for user select any one they want to use.
Thank you
(3,265 Views)
you could use a case structure and wire your ring control to it and then send the frequency you from the case structure
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,257 Views)
  In Ring control it has Max limit up to 65535. I would like to change the limit because my Freq range higher than the limit.
(3,253 Views)
Accepted by topic author stevevantran
Change the representation of the ring, it defaults to U16.
(3,249 Views)
 Hi Darin,
   Thank you for your help.
  Steve
(3,228 Views)
